Originally posted by scottkz
View Post
What did you do to your 90 today?
Originally posted by glen_ep View PostOh what the hell, here's a couple pics of my progress in learning to weld. Here I'm reinforcing the rear tank guard using some scraps. I figure this is the most productive way to practice as it's both useful and non-critical.95 3.0 Camp Car, 150 V6 Daily Driver[SIZE=4]
[/SIZE]
Originally posted by scottkz View PostWouldn't have a clue on model numbers but visually it looks identical to my 1201kz auto transfer (I have a 120 box it my 90)
Looks like the whole thing will just bolt up as normal !!
Just need to find a 4wd actuator motorglen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by fridayman View PostLooks a bit like some of my welds before I discovered a flap wheel attachment for my grinderglen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by glen_ep View PostAre you referring to pre or post welding? I did grind those beforehand but have since realised a flap disc does make things much shinier compared to a grinding disc.95 3.0 Camp Car, 150 V6 Daily Driver[SIZE=4]
[/SIZE]
Welding is a bit of technique and an awful lot of practise. Once you have the first bit right the second is what makes it pretty. Ugly welds work too though.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by mjrandom View PostWelding is a bit of technique and an awful lot of practise. Once you have the first bit right the second is what makes it pretty. Ugly welds work too though.[I]Maroochydore, Sunshine Coast, Queensland[/I]
Originally posted by juc33_prado View PostI assume all is ok, Nothing looked untoward, and I haven't had anything drop out yet
The lift was +75mm from where is was sitting, front was sitting perfect prior to lift, back had a little sag in it from 14 years of prior use...
http://www.pradopoint.com/showthread...light=dobinson
Originally posted by mjrandom View Post. Ugly welds work too though.
Sent from my iGizmo using Tapatalk2014 VX D4D. Dobinson 2 inch lift. TJM T3 Bullbar. rhino platform. TraxRax. Maxtrax. Dual batteries. GME TX3450.
Originally posted by Ian Reid View PostGod thats a relief. Was thinking of getting a welder but haven't done it since school, crikey nearly 40 years ago. I'm thinking there are gonna be some ugly welds and a lot of grinding.
Sent from my iGizmo using TapatalkMy 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
i converted my V6 to a 1KZ diesel auto, at the time and probly still now the 95 series diesels are rare and rocking horse SH*T in perth and this 120 kz auto was sitting around at a wreaker.... its out of a 04 120 but id say its identical still only a 4spd
im also running the 120kz ECU aswell
still got the V6 diffs as there better ratio for economy
a mate is doing the same conversion now so it will be interesting to see if theres any difference in ECUs or boxes
front diff drops down the pass side
visually if you saw them both on the floor you wouldnt tell the difference unless you Really knew what to look for
i do need to find the 4wd actuator motor for it though as it was missing , hoping my 120diff lock motor will work(they bolt up in the same bolt holes) other wise i have access to a 95 series center diff lock motor
Thanks for the info Scott. If I research a bit more I'll probably work out what that transfer model is. I'm definitely keen on a 2H/4H/4HL/4LL transfer, but I don't have any plans to change the transmission.
On topic:
Tonight I performed some more welding for the Prado (more pics in my build up thread)
Originally posted by glen_ep View PostThanks for the info Scott. If I research a bit more I'll probably work out what that transfer model is. I'm definitely keen on a 2H/4H/4HL/4LL transfer, but I don't have any plans to change the transmission.
On topic:
Originally posted by Rainman View PostI'd be keeping a close eye on my CV's if I was you, particularly as it looks like you have standard size tyres on the RV. Here's a little bit about my experience with an over zealous lift using Dobinson springs.
I will have a squizzy this avo!
SAM[I]Maroochydore, Sunshine Coast, Queensland[/I]
