Hi
I've just had some mods done to my 2008 prado. 4" snorkel fitted, custom airbox, stage 3 GTurbo, +30% injectors and a FMIC fitted. Engine started fine but as soon as you start to accelerate the engine light comes on and goes into limp mode (does not even boost up). The code indicates throttle pedal but i swapped this out and the fault re appears.
P2122 - THROTTLE/PEDAL POSITION
SENSOR/SWITCH ”D” CIRCUIT LOW INPUT
Any ideas????
Any ideas????
