Chasing some advice from Prado 150 owners that use a stone stomper and have the OEM exhaust.
Have you had a "turn down" exhaust tip fitted as per Christian's recomendation or did you stick with the factory configuration that is angled slightly towards the ground already?
I am about to fit a stone stomper and don't want to get the current exhaust modified if I can avoid it as the whole setup will be changed in another month or so, but with that said I am about to embark on a 4k trip and don't want to burn the stone stomper before I get back!
