Looks great Chippy, those tie downs for your fridge are they rated (kgs) ones or are they the Brass jobs, i have been looking for the rated type which lay flush for a while. Anyway the carpet job finished it off nicely, Russ.
Home made drawers under $110. Basic measurments added
This is a sticky topic.
Just a thought chippy, since your finished....
With the rear set up of mine, I put the fridge on the passenger side. I dont know about your camper, But with mine i cant open the rear door all the way if its still hitched up.
So, if the camper is on, I can still get the fridge to slide out for access..
But then again my fridge slides under a shelf. you could just sit next to your and open it... I think I'll just shut up...
But it sure looks pretty with the wall to wall carpet.
Jeff.Reminds me of my safari in Africa. Somebody forgot the corkscrew and for several days we had to live on nothing but food and water.
W. C. Fields (1880 - 1946)
drawers
Great job chippy, It makes me think that I might sell my full drawer set up and build a half job to allow the rear seat to be used or more space for the extra pram needed now. hmmmm. KMK2004 3.0L TD GXL manual, Bilstein & Lovell springs 2inch lift, PolyAir Bags in rear, Piranha Dual Battery tray, Baintech Battery Isolator, Toyota Electronic Rust Protection, Sovereign Bull Bar
Very nice jpb Chippy.
Looks like you went on a shopping spree at UES.
I ended up using what I could find at Bunnings.
Where did you get the bearings from for the draws?LC 120 03 GX V6, Bonnet/Head light Protectors, Home Made Draws.Toyota Tow Bar.Cooper ATR 235/70/R17 RE+. Toyota Bullbar with fog light. Navra 150 Spot Lights.
[url="http://tikarn669.googlepages.com/home"]http://tikarn669.googlepages.com/home[/url]
G'day Len
Being a Rockingham neighbour you should find these guys quite handy.
I got the bearings from Kwinana Bearings and Belts in Burlington Street, Naval Base.
From memory I used a set of the 10 mm i.d / 30 mm o.d ball radial bearings .... held in place with cup head bolts and locknuts.
Their web site, with address and contact details, is http://www.wozwebs.net/bearingsandbelts/
Chippy
Draw Fasteners
Hey Guys,
I am about to start my draw system and I am looking for some type of lockable draw fastener. The commercial systems have large handles which open a spring tongue and can be locked with a key. Is there anything like these in the general hardware stores? Alternatively, what have others done?
Thanks.2003 Prado Grande deisel. Sovereign bar, 9500 lb Warn winch, DP chip, 3" exhaust, ARB rear diff locker, ARB dual battery and compressor, safari snorkle, GME 3440 UHF radio, reversing camera, 2 in. lift kit, DIY drawers, DIY cargo barrier, Platinum drop-down fridge slider, Engel 40l fridge, under bonnet hot water system, Kaymar dual wheel carrier rear bar, Custom Boat Loader roof rack.
These Drop-T handles come in either key-lockable or non-lockable format.
I went with the non-lockable as I didn't see the need to lock the drawers inside the vehicle.
Check out these guys .... I got mine from their Perth office
UES (INT'L) VIC
38-40 South Link,Dandenong VIC 3175
PO Box 4385,Dandenong VIC 3175
Tel: +61 (03) 8787 3100
Fax: +61 (03) 8787 3102
E-mail: [email protected]
Chippy
Hi Chippy,
Another great job, I might try the same on the opposite side as the Lab thinks she owns that space.07 Upgrade GXL D4D, Manual, Dune,Sov Bar, BFG's, SG11, Redark dual Batts, Extensive Aux wiring, Stebel, LED stop tails, IPF HID's (my mod), 240V Inv, ARB Comp, GME UHF,TPMS, Safari snorkel, GPS,Hilux washers, 40l Engel in 30% pas pos,homemade A/C cond protection plate, polyairs.
Thanks to Mumsrig for the inspiration and all the others for different ideas Justo and myself have made a set of draws to suit our individual needs.
Thanks to Justo for his expertise and professional equipment i don't think they came out to bad.
All up the 2 units will owe us about $600.00 in materials
These are my draws Justos will follow after i cover them :roll:
Base made up and trial fit. I actually put a 50mm face on the first pic
Top attached with fold up sides
Attached the front by removing the existing tie downs in the car and locating holes in the drawer with 50mm high tensile bolts whilst at the back i used these adjustable tie downs which work a treat. Less than 5mins to remove the whole drawer system.
Draws installed and i found these neat push button latches which we will have to see whether they stand up to the test.
Finished item after many ales and lots of glue fumes.
Stay tuned for Justo`s which are quite different and they look greatCheers Moto
2007 Grande crystal pearl D4D auto
Originally posted by ChippyI'm curious about the shape Justo picks ... as they probably need to have a built in bean bag for the dog :lol: :lol: :lol:Cheers Moto
