I've been looking through all the postings/photos, and have to congratulate everybody who has designed & built thier own system to suit own requirements.
A couple of Q's & comments I have:
MDF v's particle board: is there any preference as far as longivity is concerned.
I am tending towards plywood (marine ?) thickness yet to be decided.
Any preferred thickness ?
I observed a design that incorporated a decent size water tank, would it be possible to have a water tank and a cargo barrier at the same time ?
When "profiling" to the curvaeous nature of the cargo area how much clearance has been left to allow for vibration & lifting up the side panel for access to the (oem) jack hidey hole.
Thanks in advance guys
jarrah7
2008 GX turbo diesel auto 5sp Fitted: snorkel dual battery kit kaymar twin wheel carrier Evenutally fitted: Bullbar VHF & UHF radios, storage system Still to come: winning lotto number to pay the blessed thing off set of decent side steps/rock sliders
Too many projects so little time and even less money
MDF is fine as long as you don't get it wet. I wouldn't even consider particle board. Preference goes to plywood as it doesn't swell with moisture, will last longer and due to having several laminates it will be stronger for the same thickness. Marine ply is good but probably overkill. 12-15mm is ideal and 18mm is getting a bit to heavy for a complete system.
Leave enough room for your carpet to wrap around the side panels, they can be a "snug" fit but not over tight. Keeping the side panels snug will help eliminate any rattles and movement. As for the side panel access if you keep the main drawer unit inside of the wheel arches and the rear tie down point there will be enough room to get the jack out.
Good luck 8)
If I had to buy material I would have bought a good quality ply. But as the MDF was left over from making a box in the garage for the kids outside stuff (cricket gear etc) I just used the leftovers with spare holes and pencil lines.
As Justo mentioned as long as the MDF stays dry it will be ok but good quality ply is definately better as it is stronger in all directions.
Also my little fridge support board and drawer is very low load and low weight. Building proper drawers I would have bought ply because of the extra loading on the material and joints. Just make sure you get a structural ply, some of the indoor stuff is as weak as a kitten because the ply joints sometimes line up across the plies.
The most durable material of this type I have used is form ply, the stuff that concreters use for formwork. I made a camping kitchen bench out of form ply about 15 years ago and it is still the same as when I made it regardless of rain and wash downs. But form ply only comes in 18mm thickness so is too heavy for this application in my view.
Michael
In my last design (just a shelf with two support walls/sides) I had a 20 litre jerry of fuel & 20 l of water on one side, and the number of times those blasted lids leaked, causing the MDF to swell was a bit to frequent for my liking.
I will certainly be looking at Plywood dunno why I typed particle board ops:
Form plywood certainly seen it but as you mentioned its a bit heavy for my criteria.
"As Justo mentioned as long as the MDF stays dry it will be ok but good quality ply is definately better as it is stronger in all directions."
What's the consensus on the best fridge slide? My requirement is that it fits a Waeco CF50 and locks in the open position as well as closed.
Most of my looking has been at what you get for the money... also, now I'm trying to keep it close to a certain size.
So... my requirements became...
Sturdy, locks closed and open and is a generic fit...
The thing that is pushing me towards the ARB fridge slide is that it's almost the perfect length (for my needs) 720mm. Not due to the fridge size but maximising the space in the back of the Prado.
To top it off... it's only $275.00 from ARB.
I haven't tried/used any slides so this is just my observations...
Cheers, Leon There's no such thing as a wrong turn... it's just the scenic route!
1998 VX Grande 95... gone, 2008 GXL 120... almost gone... 2017 GXL 150... blank canvas Optix Photographix
We also have a Waeco fridge slide with a CF50 on it. We put some high density foam at the back of the slide so the catch that holds the slide in the shut position was held in place tightly and that sorted out all rattles.
Scott
Bought the ARB/ENGEL slide on Thursday arvo... so far no rattles but haven't been offroad yet
Scott
Sounds like a good solution. Do you have your CF50 in a bag? If so how does it fit in the slide? Does it lock in the open position?
Yes ours is in a bag and it works fine. We use tie downs to hold the fridge in place but I am not sure if the metal attachments that Waeco sell would work with the bag. Ours is now in the second car and has been there in some particularly rough 4wdriving and has never moved.
The slide locks in both the in and out positions. I will take a photo later on today.
Scott
I have put below a couple of photo's of how our setup works. I couldn't get to the back of the fridge easily to show you where the foam is however if you have a look at a slide it will become obvious.
This one is with the fridge locked in the out position.
