just fitted the ironman underbody protection - with a few adjustments i got them to fit . not to bad otherwise
looks good now to just go and test it out! there priced pretty good and protect so much its worth the money they cost.2012 Suzuki jimny 50mm lift, 215/75/15 hankook muddies, 30 inch dual row light bar, gme UHF, arb compressor, rola roof rack, ironman awning, projecta dual battery system with yellow top optima, evakool fridge freezer and arb air locker this month!
I had seen the advert in a mag recently and thought that for the $$$$ it seemed reasonable value for new plates.
Good to see that they also cater for the 150 series.
cheersStewy
yeah i saw that ad in a recent magazine as well. It looks like they cover from the bullbar all the way back to the rear tailshaft. Oceanrider, any chance of a couple more pics showing what they cover ??? I noticed your original ones looking a little worse for wear.
Phil06 120 GXL 1KZ-TE man, modified exhaust, K&N, OME 2",spacers, Sovereign BB, Safari Snorkel, Hella 4000, 33" muddies, ARB 60L fridge / slide ,custom rear drawer, cargo barrier and table, Ironman 9500lb Winch, TJM underbody guards, DIY Radiator bash plate, Outback Ideas recovery points, AJ's sliders, CKMA12, lockers, ext rear breather, UHF, dual batt, SBi12, ARB alloy roof cage, ARB side awning...
I went and had a look yesterday and the ones fitted to their Hilux looked fine, in all reality as long as they cover the areas required and are sturdy (3mm) they will do the job.
The paint is average and rubbing off already, SA5 coating option would be good, and the bolt heads aren't protected so will be susceptible to damage. The salesman also offered to fit while you wait for $88.00 which I thought was reasonable.
See ya on the tracks, Richo.[B]Former [/B]Party Leader, [B]Now[/B] SDO SEQLD GTG 2015 PFA (Pradopoint Fairy Advisor)
I knew about these 12 months ago and told a few people. I'm glad the release date was delayed as I am very happy with amts plates. That said, in the absence of his plates I beleive i would get these ones.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Hey trekrider, im in the same situation as you. I just ordered the front tjm one as well for 240 Will be picking it up when in syd next week. I noticed the new sump guard they do doesn't have the front diff exposed anymore. I checked ATMs and theirs in suitable either, looks like tjm are the only ones that suit if you only need the front one
Cheers Phil06 120 GXL 1KZ-TE man, modified exhaust, K&N, OME 2",spacers, Sovereign BB, Safari Snorkel, Hella 4000, 33" muddies, ARB 60L fridge / slide ,custom rear drawer, cargo barrier and table, Ironman 9500lb Winch, TJM underbody guards, DIY Radiator bash plate, Outback Ideas recovery points, AJ's sliders, CKMA12, lockers, ext rear breather, UHF, dual batt, SBi12, ARB alloy roof cage, ARB side awning...
Unless you want to replace with another original one.....lol!06 120 GXL 1KZ-TE man, modified exhaust, K&N, OME 2",spacers, Sovereign BB, Safari Snorkel, Hella 4000, 33" muddies, ARB 60L fridge / slide ,custom rear drawer, cargo barrier and table, Ironman 9500lb Winch, TJM underbody guards, DIY Radiator bash plate, Outback Ideas recovery points, AJ's sliders, CKMA12, lockers, ext rear breather, UHF, dual batt, SBi12, ARB alloy roof cage, ARB side awning...
Originally posted by Trekrider View PostThanks Phil, I guess it's the TJM one for me then.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Originally posted by Trekrider View PostI thought the amts plates were a complete set - I only want the one to replace the Toyota front guard as I already have the TJM (old style) sump guard.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
I spoke to the guy from amts at length, and we went thru all the options. I sent him a photo of the tjm one i already have on. The amts one is a complete piece where the original toyo one is in 2 pieces. The tjm is the only one that is in 2 pieces and can match up with the original ones. If i was buying the whole lot it would be amts for me, but i'm going tjm to save a few bucks.
Hope this helps trekrider.
