Hi All,
I installed my ARB compressor weeks ago and thought I had better show you all.
I used 3"x11/2" T6 Aluminium channel bolted together with an 8mm S/S bolt and nyloc with lots of Durolac to make my mounting "I" beam, as the redarc and fuse panel makes that corner of the engine bay very cluttered so I needed to raise the weighty little beast.
I still have room to access the secondary fuel filter drain valve and it clears all flexible hoses.
The wiring is as per the rest of the guys, with mine being wired to the Auxillary battery and relay control +Ve taken from the Ign cct.
A general view:
The small Air Reciever and fittings to relocate the pressure Sw. Chair rubber stopper keeps crap out of instantaneous air fitting.
View showing the Mounting bracket, lots of durolac between mounting faces and S/S mounting bolts, steel plate as supplied is under guard drowned in Tectol let dry then coating of Bitumastic paint.
A general view:
