Got my winch fitted today(ATS in Geelong) was told by Opposite Lock in Qld, that the Tmax would fit the Toyota sovereign bull bar with the Toyota winch fitting kit($245.00) well Cliff at ATS tried to fit the winch but the Tmax Fairlead would not fit, but Toyota could provide a Fairlead that would fit, only problem they could not supply for a few more days (about $200.00) however Darren came to the rescue with a alloy fairlead ($175.00) and plasma rope ($275.00) that had to be fitted because of the alloy fairlead and a mounting bracket that sits on the bull bar (not supplied by Tmax!) another $36.00!
Tmax winch and Toyota Sovereign bullbars
2005 V6 Grande, Sovereign Bull Bar, Piranha Dual Battery System with dash monitor, GME TX 3440 CB, Impco Gas conversion, Tmax Winch with Plasma rope, Outback ideas recovery points, ATS suspension upgrade.Sandgrabba mats. Milford Cargo barrier.Rhino roof rails.Tags: None
Stevo, your still much better off, you ended up with a great winch, got rid of the horrible steel cable that comes with most winchs, in the process saved your self a few dollars & Kgs with the lighter & safer rope.
Which model winch did you get as the 10,000lb Tmax winchs have a heavy duty fairlead which is slightly larger than the Warns due to thier heavier construction, I had no problems fitting them to my TJM bar, plenty of room for a 15,000lb winch2007 D4D auto, Tunit Power Module, Scan GaugeII, Bilsteins & lovels HD, raised 50mm front & 60mm rear, 10,000lb Tmax winch, 7/16th Amsteelblue synthetic 23,000lb winch cable, TiTan HD winch solenoid pack, Outback draws with fridge slide & 50 litre Waeco, Ryno roof rack & Alloy Cage & extra set of Rhino HD Roof bars x 3, TJM type 15 steel Bullbar powder coated silver, Dual battery setup with custom tray, Bosch Navigator spots with 55w HID kit, Sand Grabber mats, Toyota Tow Bar, Sensor Touch Electric Brakes, Cooper ST 265/70/17 tyres, Uniden remote head UHF radio, Modified Milford Cargo Barrier, Extra power points in the back run with 10mm wire for fridge & inverter, Anderson plugs with 10mm wire front & back for the camper & compresor conections. 7 inch in dash JVC DVD player with bluetooth & Ipod adaptor, 39DB Stebel High Power TM80/2 Magnum Electric Horns. JL Audio 300/4, 300/2 power amps, Pioneer TS-C160R front splits & TS-D161S rear speakers & 12" Pioneer sub
Got the 9000lb winch, the Toyota Bull bar had no problems fitting the winch just the fairlead, it would not fit in the space toyota provided, and of course I would rather have the Plasma than wire, it was just a shock when i got the bill!!!
cheers2005 V6 Grande, Sovereign Bull Bar, Piranha Dual Battery System with dash monitor, GME TX 3440 CB, Impco Gas conversion, Tmax Winch with Plasma rope, Outback ideas recovery points, ATS suspension upgrade.Sandgrabba mats. Milford Cargo barrier.Rhino roof rails.
Hi Joey
wish you had sent the photos before, did you require a Toyota Fairlead Bracket on the outside of the bullbar? noticed you mounted the controller box inside the engine bay (thats where my second battery is), mine is sitting on top of the bar just above the winch( where your spotties are mounted)
Will try and organise photos soon,
no didn't fairleads from toyota...did some research and had than take half a mm from the edge and it fitted perfect without compromising strength..
i have moved controller box now to back of engine bay along with compressor as my battery goes in next week.....
all good...Featured - issue 140 Australian 4wd Action.
-issue 52 Modified 4wds .
well as they say, you live and learn! Don't you like sleeping in Chippy? must be 5.30 am over your way!!2005 V6 Grande, Sovereign Bull Bar, Piranha Dual Battery System with dash monitor, GME TX 3440 CB, Impco Gas conversion, Tmax Winch with Plasma rope, Outback ideas recovery points, ATS suspension upgrade.Sandgrabba mats. Milford Cargo barrier.Rhino roof rails.
mi likim som pla sleep. body bilong mi big pla skin di.
thats means im tired and like sleep...Dam png :shock:Featured - issue 140 Australian 4wd Action.
i also had to shave/grind a very small amount off my fairlead to fit it into the toyo bar.
i remember seeing also (someone posted not to long ago) that someone fitted their winch and had to trim the winch cradle (very slightly) to fit the bolt heads of the winch gearbox.
i also had to do this on my install.
so toyota only made the bar and cradle to suit their winches (superwinch X9). typical :?[url=http://www.fuelly.com/driver/damonat/prado][img]http://www.fuelly.com/smallsig-metric/50578.png[/img][/url]
Howdy all!
After a few searches i found this (exactly what i was after)
so some questions for you guys who have put in a TMax winch;
1- Fitting one of these to a soverign bar that has never had a winch fitted before, what extra parts (ie, parts not supplied with the purchase of a new winch) need to be purchased, and
2 - part numbers for any of those parts,
3 - modifications in relation to above?
4 - Any precautions using any other winch other then the Toyo genuine winch?
Thanks in advance!2006 GXL V6 5SP Auto.
Cooper ST 265/70R17 / Lightforce XGTs / ARB Deluxe RoofRack with Shovel + Holder / Recovery Hooks / Recovery Gear / SandGrabba Mats all round!
Oh, and Its White! Wait!! I've also fitted one of those Scan GuageII thinggi's!
Wish List: New suspension, Winch, Bashplate, and Upgrade an 08 Update'd Prado D4D... Not that 06 was that long ago!
[url="http://www.youtube.com/watch?v=wqkz4RAYmdE"]http://www.youtube.com/watch?v=wqkz4RAYmdE[/url] << Some Wild Video Footage of it in Action!
As you have probably read, you will need a Toyota winch bar fitting kit, was quoted $197 from dealer but I later found there was only 3 available in the Eastern States and it finished up costing $245.00, then the installer had a problem with the Roller Fairlead, it wouldn't fit, (as others have explained there has to be some slight cutting to the Toyota bull bar, but with patience it will fit as others have said) I finished up getting Plasma rope, all up about $500.00 to get it installed,( the bullbar has to come off and there is a lot of fiddling)
cheers Stevo2005 V6 Grande, Sovereign Bull Bar, Piranha Dual Battery System with dash monitor, GME TX 3440 CB, Impco Gas conversion, Tmax Winch with Plasma rope, Outback ideas recovery points, ATS suspension upgrade.Sandgrabba mats. Milford Cargo barrier.Rhino roof rails.
actually its the fairlead that needs the slightest of shaving to the edges,not the bullbar....ends up a easy fit.. most 4x4 suppliers will tell or organise this for you, especially if you let them know in advance!
CHEERSFeatured - issue 140 Australian 4wd Action.
Hi Joey
I am surprised the installer had a problem with the fairlead, he rang me and said it would definatly not fit and they are 4x4 specialists!( ATS in Geelong),cost me an extra $450.00 for the Plasma and American alloy fairlead.
