OK
After doing the design for the front recovery points.........based on Samo's drawing, I thought maybe the same principle could be aplied to the rear.
The following design is for information only, if you construct them, you do so at your own risk. The design has not been built, has not been tested and has not been rated
I am supplying the design so we can discuss whether or not it would work.
