Warn Winch Control Box Mount
  • Warn Winch Control Box Mount
    Hi,
    Am new to prado point. Have read the threads I have found on winches but was unable to find an answer to my question. I have a prado with ARB winch bar and have recently had a warn winch fitted. It is an older model winch and I am unhappy with the look of the control box. It appears to sit very high and looks out of place. The newer ones I have noticed slope down so that the bottom of the control box is almost sitting on the bull bar. Mine sits flat but is on a bracket that sits about an inch above the bar. I was wondering if anyone has had one fitted or fitted it themselves elsewhere. Under the bonnet? or behind the bar?
    Thank you for all the usefull info I have found on here already. The site is a fantastic resource.
    knjoyce
    Re: Warn Winch Control Box Mount
    viewtopic.php?f=16&t=3922
    viewtopic.php?f=4&t=778
    Mick
      I didn't want the solenoid box blocking air flow so I fitted mine under the bonnet behind the driver's headlight. It's a PITA getting the power cables through but in the end it worked out ok. You can also see where I mounted the Warn remote.
        Awesome. Thanks so much
          If you mount the winch solenoid pack under the bonnet you can always put an in cab winch control so it does not require running the trigger switch through the open hood. I know several others here has done it.
          Just an idea.
          -Ben
          "Don't worry about the world coming to an end today. It's already tomorrow in Australia" (Charles Schultz)
          I have a 2007 FJ Cruiser (An American knock-off 120) Considerably built up.
          I am also a Founding Father of the FJ Bruisers, FJ Cruiser club, in Washington D.C.
          Check us out....
          [url]http://www.fjbruisers.com[/url]
          Our discussion forum....
          [url]http://www.fjbruisers.org/forum/[/url]
            As far as air flow goes, I have a bar, winch, driving lights and the control box sitting in the normal spot between the lights.
            On a normal day the scanguage says that I operate at 88 deg c. On the recent 47 deg day I was driving around, both stop start in traffic and on the freeway and the scanguage got to..........................88 deg c.
            So I don't think airflow is that much of a problem
            December 2007 Prado GXL diesel, Option Pack with traction control, rear airconditioning and curtain airbags. Lovells Springs and Bilstiens shocks, snorkel, front recovery points,
            ARB Bar with fog lights, ARB second battery system, sandgrabber mats, Pirelli ATR Tyres,
              I have been thinking about the possible problems with blocking air flow on my car for a while. From the pic (if it works, it's my first attempt) you can see that we have a bull bar mounted with spoties and the winch controller. I often wonder what factors of safety the designers have put into their designs? Did they know that people like me would stick obstructions in front of the grill and drive daily in the Pilbara?
              That aside I have never seen the guage above half way let alone overheat the car, but i do wonder how much harder the cooling system needs to work to counter for the reduction in air flow and what effects on fuel economy/wear that this may cause.
              I would be interested in hearing others thoughts and experiences on issue so please throw in your 2 cents.
              Will
                Originally posted by Wil
                http://www.postimage.org/image.php?v=gx5vYe0
                ... (if it works, it's my first attempt)...
                Well, you were very close Wil. Simply edit your post and replace the "http...." with the BBcode from your picture page.
                You can use the "Preview" button before submitting, so you will see how the post will look.
                LFaR.
                  Thanks for pointing me in the right direction.
                  Will
