Hi all
My 2004 GXL doesn’t have the roof rail option, so I purchased some genuine used ones from Marketplace.
I’ve been having trouble fitting them tonight and have a couple of questions:
Where do these long brackets go please? Is it underneath the rear bolts? It seems that if I place them there, it lifts the racks up too much, i.e. there’s a big gap between the gutter cover and the rubber bottom of the rail.
And is this how the mounting bolts attach to the middle arm? It seems wrong to be bolting them down tight onto the paint with nothing in between, especially when there are rubber washers on the bolts. It was also quite hard to tighten and they don’t feel completely solid - there’s a small amount of movement. I’m worried I’ve got these mounted wrong. There’s also a fairly big gap between the gutter cover and the bottom of the middle mount section too when I offer it up. Looks like it will definitely cause some kind of whistling/wind noise as is.
Lastly, does anyone know where I can get a cheap replacement end cap locally? Toyota weren’t any help because my VIN didn’t give them the part no….
Thanks!
Thanks!
