Recovery points at the front?
This topic is closed.
  • Recovery points at the front?
    Ok, so what are you guys using if you need to get recovered from the front?
    Is the standard welded loop at the bottom what you use, or do you add something, if so what?
    Or do you have recovery points on your bullbar?
    2007 Prado Grande
    I think this topic has been covered here several times, please try searching for front recovery points.
    Don
      Found this....Recovery Points As Don said above, try searching in future in the top right hand corner...
