120 Prado B Pillar Rattle
  • 120 Prado B Pillar Rattle
    Hi guys,
    in my newly picked up 120 series 2007 (53,000km) I am noticing a slight rattle. I haven't been able to pin point where it is but it sounds like it's coming from the pillar on the driver hand side inbetween the first and second row seats (right in my right ear basically).
    It sounds like the pillar is hollow and little tiny rocks are constantly falling down it and hitting the sides on the way down. That's the best I can describe it!
    I noticed that it only seems to start when I go over 90-100km/h and its in no way linked to pot holes or bumps in the road. I was thinking wind but then again, no obvious pattern as it doesn't make a noise in sync with wind gusts!
    If anyone has experienced this or know of it or even if you don't know of it if you can advise where would be my first port of call to try and see what is causing it. I've checked all the door pockets etc to see if theres a coin rattling around but nothing!
    Help please!
    Loz
    Loz - 2007 GXL D4D Auto White
    ARB Deluxe Winch Bar, 2" OME Lift, ARB On-Board Air, Safari Snorkel, GME TX3440 UHF, GME AE4018K1 antenna, Redarc/Exide ED5 dual battery system, ARB 47L fridge, Cooper AT3's 265/70/17, LeighW's voltage booster, Lightforce 240XGT's, Outback Solutions Drawer Systems
    [url=http://www.pradopoint.com/showthread.php?20863-Loz-s-120-GXL-D4D-Prado&highlight=loz%27s]My Rig Build-Up[/url]
    Seatbelt movement??
    Greg - 08 D4D Prado,
      the best way I have found to find rattles is to go outside the car close all the doors and tap the point where it sounds like is coming from with the outside part of your hand with a closed fist, sometimes it helps to have someone else do it while you hold your ear up to the car.
      Sounds like a very strange one though.
      Do you have roof rails? perhaps check the covers that go along where the roof rails attach.
      Other option is to start removing panels from the inside to see if there is something lose in there.
      Andrew
      2005 VX Diesel - [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12823"]My Rig Buildup[/URL]
      [URL="http://www.fuelly.com/smallsig-metric/65233.png"][img]http://www.fuelly.com/smallsig-metric/65233.png[/URL][/img]
      [B]Bitumen - A blantant waste of taxpayers money![/B]
      [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12197&start=0&st=0&sk=t&sd=d"][/URL]
        Hi,
        Nah it's not the seatbelt
        it sounds more like maybe a loose wire that is rattling in there... are there any wires that run through that b pillar?
        Today on the way to work it didn't do it at all. Then on the way home it started (at 70km/h this time though!)
        What else could be rattling inside there? It's not real loud, you won't even hear it with the window down or radio on... but I know it's there and it's driving me crazy!
        Lorenzo
          Not to upset you but the sound may originate somehwhere else and simply travel to there. I thought I had a rattle near the rear steps and it was the rock sliders hitting the car!
            Hey Loz
            I have had a similar problem that I've tracked down to the door seal at the front edge of the rear passenger door.
            Applied a bit of Mr Sheen to the seal and door frame and all quiet for a few months, then redo.
            See how that goes!
            Ron
            Ex 1988 Mitsubishi Pajero V6
            Ex 1986 Suzuki Sierra
              Ron,
              I rubbed some vaseline into the rear seal (only did the section closest to me), then drove 35km back home and guess what....
              IT WORKED!
              no more rattly noise... Looks like the seals were a little dry, rubbing against the pillar and making that funny noise.
              Thanks mate your a champ!
              Lorenzo
