Brackets and cooler lines under radiator
  • Brackets and cooler lines under radiator
    Is there anyone that can check the following for me as I am unable to do it do to work committments:
    "Can you double check for me on your car (120 diesel Grande with trans cooler), as to whether you have the transmission cooler lines running near the bottom of the radiator? The reason is due to this post (bash plate post) which shows brackets holding the trans cooler lines being attached to the cross member under the radiator. If you have this bracket, then you will need the V6 version of the bash plates.
    This is kind of urgent.
    This is the bash plate post Rob is referring to
    http://www.pradopoint.com/showthread...l=1#post284151
      Looking through toyodiy, this is the only reference to the oil cooler in the 2009 D4D auto http://www.toyodiy.com/parts/p_G_200...AGYQ_3514.html
      The oil cooler tubes seems to connect to something else.
      Comparing this to the 2009 V6 auto, it shows the tubes attached to the 2 brackets http://www.toyodiy.com/parts/p_G_200...AGKQ_3514.html. Click on part number 32907A and it will highlight the part in the illustration.
      I then checked the manual version of both the D4D and V6 and there are no references to oil coolers.
      So to summarise, only the V6 auto has a transmission oil cooler in front of the radiator and have 2 brackets mounted to the cross member under the radiator.
        I do have an auto trans cooler in front of my radiator with a fan that Matty keeps threatening to pinch! I do not know about the 2 brackets mounted to the the cross member under the radiator, althought doesn't the ARB plate cover these anyway?
