Most lifting lugs, plate clamps and so on are normally yellow plus yellow will be more visible for some one to hook ya in a situation where you are unable to get out of the car but that's just my opinion (unless your deep in mud)
Recovery Points
Yeah gumboots GR360 used for making teeth for buckets on front end loaders and the likes so will be more then strong enough. Had a look in the plate rack at work today and found some 12mm GR360 so material is sorted, I will ring a load testing joint tomorrow just to get some info and prices and then go from there
Originally posted by craigm View PostGeez wouldn't it be great if we finally had a resolution to the 120 Front recovery points issue on ARB Bars!!! Fingers crossed boys that these fit up OK....
Originally posted by BrettM View PostI have a set to check the fit to your prado Trekrider, I have your number so I will give you a call during the week to sort out a time to check the fit, Cheers Brett[B]Robert
Originally posted by AJ120 View PostThey seem to have 3 holes in those 150 recovery points, I can't see how you could use more than 2 of them in the 120. I imagine they would also hang fairly low.
http://www.ebay.com.au/itm/271045497...84.m1438.l2649
I was looking at these points for my 150, still trying to determine if they will fit my TJM T13 bar.
Originally posted by fido666 View PostThe 3rd hole is only used in the FJ Cruiser according to the Everything4WD listing on ebay :-
I reckon that they will fit your bar.
If in doubt get the OI points as they work fine, but,, I do use a bridle strap.
REV
Originally posted by REV View PostI have the OI points on my TJM T13 bar and these look to be the same, apart from the hole for the shackle.
Originally posted by fido666 View PostDoes your TJM T13 bar have the wing plates on the underside of the bar? Maybe I'm blind but mine does and I can't see the mounting points as a result. Also I will just mention again I have a 150 not a 120 in case that matters.
Yes mine does have the plates and mine is a 150 also. I haven't looked too closly but I doubt that you would get these points on to a 120, would you?..................Anyone?????
