Hi Guys and Ladies,
This has been mentioned before somewhere briefly, but I will raise it again, if you have a Towpack fitted the plug wiring from the relay passes through not one but two rubber grommets the both of which were never popped into position by the installers on my new GXL allowing heaps of dust into the jack compartment and underbody compartments evetually bleeding out of the jack removable access panel.
The first grommet is about 50mm diam. and is located to the inner rear corner of the jack compartment, very hard to get access even with the jack removed but is possible to pop back into hole as it slides easily down the wiring loom.
The second grommet is also about 50mm diam. under the L/H rear, if you lie on the ground and look up, easy to get at but a bugger to pop into position I use a bit of spit/saliva around the sealing lips of the grommet to make fitting easier.
Their is also another grommet outboard of the lower one which I used for a Fog lamp mod stop/tail wiring which would also be worthwile checking.
No more dust ingestion! hope this helps
