Inner guard crack repair
  • Inner guard crack repair
    Hi all, I'm new to the prado world and have been doing a lot of research before purchasing. I'm looking at buying an 06 to 09 with the d4d. My only hesitation is the cracks in the inner guards. On the few Prados I've checked out, small cracks are starting (mainly on LHS). I've read heaps of what causes it and seen the photos, but what I want to know and can't find info on, is the repair.
    -Does the repair involve a simple weld up of the crack / tear?
    -Once repaired, does the guard then find another place to give out?
    -What preventative measures can be taken to avoid it happening (bracing of battery tray?)?
    Also, is it even that big of an issue? I plan on setting it up with bullbar, winch, possibly duel battery (all the good bits as many of you do). The car will be a daily but driven on road with weekend adventures. Possibly only seeing corrugations once a year.
    Any pics or personal stories are appreciated.
    Daniel
    If the vehicle has those cracks I would be politely running a mile from it. No point buying (expensive) problems. Theres always plenty of Prado's for sale.
      To clarify, what I'd like to know is if it is an easy fix or even a big issue to worry about? The rest of the car could be in great condition
        When you take it for a test drive call in to a smash repair and get a quote to repair and reinforce. This will give you a strating point to barter about the price.
          How to repair it and whether that's a big deal will depend onthe extent of the cracking, as suggested ask a local crash repairer for advice.
          As for preventing it, well lots of debate on what actually causes it and not nescessarily any definitive reason, but probably a combination of a lot of things.
          This is probably the best option for prevention http://jbl33.com/prepa_kdj120/renfort_ailes/index.html
          Not sure where you buy these panels, maybe if I could read French it might help.
            Thanks Andrew, great timing;
            I knew there where some pictures on here somewhere, but I searched high and low but couldn't find anything.
            Just about to start this little project.
            Mick
              Your welcome.
