Rattle in outer door trim
  • Rattle in outer door trim
    I've had this rattle for a while and it's been getting more noticeable. On my driver's door, the plastic trim on the lower half of the outer door-skin rattles. I think the mounting clips at the bottom have worn. It's still quite well attached but you can rattle it simply by knocking on it or slamming the door closed. It's going in next week for a warranty claim while I still have one. The other doors are fine. Anyone else noticed this?
    Yes same thing with mine. Time to pull it off and replace all the clips or some sikaflex in certain spots. Don't really want to seal the whole seam and trap water inside.
      Even with my selective hearing it's beginning to pee me off. Hopefully, Mr Toyota will fix it next week.
        Been covered before. In other threads. It's the clips. Open the door lay under it and you can see up into it. It's easy to spot the broken ones.
          Dave, sounds like it is time to upgrade to a 150. Easier than changing all those broken clips.
            Yea its the clips in the flares on the doors
              HaHa! If I'm going to upgrade it won't be to a new Prado. I'm thinking 8 cylinders and maybe only 2 doors.
                Can you get a front diff in a Maloo?
                  Apparently, if they try to remove the plastic trim to get at the clips there's a good chance that they will break the trim. I would then be up for a new trim piece plus painting! WTF? I think I will just put a little bit of silastic up underneath.
                    Holden did a concept car 427 Monaro coupe with 4 wheel drive.
                      HSV did the coupe4 which was a AWD 5.7L Monaro that was actually sold, but was slower and more expensive.
                      [LEFT]Silver 150 Facelift
                        You can get those trims off without breaking them easy. Its the clips that break. If you do get new clips for them, make sure to get all the correct ones. I think the front door trims have 2 different clips, as does the back door, the front fender has about 4 or 5 different ones and so does the back quarter panel trim!
                        And don't forget to buy the trim seal which also helps hold it to the panel(sort of like double sided tape).
                        Oh and the trims come already painted so no cost there if you do need to buy them.
                        Travelling Panelbeater
                          Finally got around to addressing the rattle in the driver's side door because I've had enough.
                          Here's the door with the moulding removed showing the 3 types of clips
                          2 grey (75392-60031)
                          3 orange (75397-35010)
                          7 blue (75495-35010)
Name:	Driver's door trim removed.jpg
                          Here's the rear view of the moulding
Name:	Door moulding.jpg
                          The cause for my rattle is a bracket that has broken off from the back of the moulding. The attachment point is so thin, no wonder it has broken off. I'll be applying Sikaflex to this one and all the other brackets as they are similarly thin.
Name:	Broken bracket.jpg
                            I just ordered some clips for mine last night, passenger side has had a slight rattle for a while. The rattle itself I can barely hear, but the noise from the passenger seat telling me about the rattle is getting pretty noisy now
                              I just ordered some clips for mine last night. The rattle itself I can barely hear, but the noise from the passenger seat telling me about the rattle is getting pretty noisy now
                              Do the clips leave permanent marks on her lips/tongue? Can you leave them on for extended periods?
