Can someone confirm the size of the bolts that hold the read door hinge to the door and to the body (11mm too small, 12mm too large!!!) and what is the weight of the rear door ?
Rear Door
Bolts are 12mm on mine!
No idea of door weight.
12mm for mine as I have undone them to reset. Why do you want to know the weight. Very very heavy with the tyre on it.Originally posted by tparvin View PostCan someone confirm the size of the bolts that hold the read door hinge to the door and to the body (11mm too small, 12mm too large!!!) and what is the weight of the rear door ?Terry
Canberra
And with 12mm bolts, what does everyone think of using the Maxtrax holders off the spare?
Would love to move them off the roof racks, but closing the door with just the standard load is difficult enough.--------------------------------------------------------------------
2004 GXL 1KZ - ARB Deluxe Winch Bar - Safari Snorkel - Dobinsons/Ironman suspension - BFG AT 265/65/17 LT
The bolts aren't an issue for adding Maxtrax, but sagging or cracking doors is an issue even at standard weight, adding more weight isn't going to help.
To avoid sagging and cracking is one reason I built my rear bar, to get the spare off the door.
12mm on 120 model, doesn't matter 2003 or 2009, petrol or diesel.Originally posted by tparvin View PostCan someone confirm the size of the bolts that hold the read door hinge to the door and to the body (11mm too small, 12mm too large!!!) and what is the weight of the rear door ?
I think you are trying bolts with the wrong thread... take 1 original bolt and get all info from your local fasteners store, but don't go to the big green shed or other DIY placesPrado [I]Grande[/I] 4.0
