rear reflector
  • rear reflector
    I have a cracked left rear reflector in my 120 VX bumper due to careless reversing ops:
    Has anyone removed theirs? I cant see an easy way to replace it.
    Prado VX D4D: Toyo Bars, IPF Spots, Cargo Barrier, GME 3440 UHF, recovery points, Ozicozi coat, Cooper STs. ATS suspension, Airtec snorkel, dual battery, Maxtraxs, Ultimate camper trailer.
    put ya hand up behind it.
    it has 1 10mm nut (from memory) holding it in.
    undo it and pull away from the car and job done
      I'm assuming the one at the very bottom (mine's a GXL). If you look underneath the bumper, there is a single nut, from memory think its 10mm socket. Just undo that and you'll find the reflector/light assembly pop out.
      Dustie
        can see the screw on the back of this one (left side) that i removed to add in some LED's.
