Water in back door
This topic is closed.
  • Water in back door
    Hi all
    I drove back from Caloundra to Brisbane in torrential rain last week. When I arrived "home" I opened the Prado's back door and heard sloshing noises. There are three plastic plugs that are almost waterproof and I had to remove the end one to get the door to drain successfully. I reckon that over half a litre of water ran out.
    I have two questions - 1. Why did I have to remove one of the plugs and 2. how did the water get in there in the first place?
    Anyone else had this?
    Cheers - John
    Dune D4D GXL, ARB bar & racks, Kings/Bilsteins, diff & g'box breathers, underbody protection, air comp, brake controller, Garmin Nuvi, Scangauge II, AGM aux battery & RanOx.
    Re: Water in back door
    Try this and see if it helps your issue
    viewtopic.php?f=2&t=4968&hilit=water+in+rear+door
      Thanks MDS69
      I should have done a search first :?
      I reckon that the reason the water couldn't get out was that red dirt plus water = mud. The plastic plugs only just let clean water out.
      I have read the thread you referred me to and still can't work out where that much water got in in the first place.
      If I am passing a Toyota dealer and feel like being messed around and told stories then I may call in and see what they have to say.
      Maybe I should avoid rain :lol:
      BTW, years ago I was given a new Maserati to test drive and its doors filled up with water too. So the Prado is in good company.
      Cheers - John
