Bash Plate Foam Inserts
  • Bash Plate Foam Inserts
    Does anyone know what purpose these things serve other than to catch and conceal mud and rocks from each off-road excursion?
    No amount of water whilst washing would get rid of the mud built-up under the foam inserts after my last adventure. I ended up dropping both plates and removed the inserts in order to properly clean the things. I am considering leaving them out all together. I would imagine that those beach-goers would face a fair chance of promoting rust in this area as it can't be properly cleaned without removal.
    Somewhere else in this forum someone mentioned the fact that the foam would catch any oil that was dropped down underneath the engine but there is only so much oil that the foam could contain. Ideas?
    Re: Bash Plate Foam Inserts
    I, for one, have no idea what foam you are talking about. Any chance of a picture or two?
    I had no foam attached to any of my factory bash plates either of the two front ones, or the one on the main tank...
    Mick
      Black on top, white underneath with a egg-carton like plastic spacer to lift the foam up in some places. It's a bit like a thin foam blanket. I'll get the camera out and try to get some shots.
        I've got the same gear, but mine is now brown. I tried to get all the mud out of it, but it's damn near impossible without wasting 1000 litres of water on it. I'm curious about this too if any body can help. I'll try and get some pics for you to look at MickL, but don't have a chance til probably Monday.
        AJ
        [i][size=2][color=#008000]2008 D4D GXL Auto [/color]- [u]BLACK[/u][/size]
        [size=2][color=#0000FF]- ARB Deluxe Bullbar - TJM Airtek Snorkel - Pirhana Dual Battery - BFG A/T's - Waeco 60L - Canvas Seat Covers - LED Spotties - Bilstein/Ridepro Lift - TJM Bashplate - GME TX3440 UHF - Rhino Roof Bars - Rooftop Tent & Awning - Poly-Airbags - ScanGauge II - Beaudesert 2.75" Exhaust - ARB Twin Motor Compressor [/color][/size][/i]
          I've had to drop my bashplates and remove the "egg cartons" to get all the crud out ofter some of the WA mud missions.
          I did wonder what purpose they serve other than to trap mud, but I've always just put them back in.
          Leachy
          EX-Prado Owner
            That would be great. I'l quite curious as to what they are.
            My theory is they are some sort of acoustic material fitted to later models or D4D's to improve NVH.
            Mick
              I suspect these are only fitted to the D4Ds and they are part of the noise supression gear.
              AndrewH
              08 Prado VX D4D, ARB bullbar, Warn 9.5XP winch, Bilstein/Lovell suspension, Polyair's, ARB diff locker & air pump, Safari snorkel, Ausguard cargo barrier, Lightforce 170 HID driving lights, GME TX3440 CB, Brown Davis bashplate, Sandgrabba Mats, Scanguage II, Rotronics independent 3 battery management (3rd in camper), Kenwood DDX8039 with Nav, Reversing camera and sensors, Blaupunkt compact powered woofer, Custom drawers, Bushman fridge, Cooper ATRs onroad & STTs offroad, PressurePro 6 wheel TPMS, Steinbauer Module.
                i removed mine after they added 20 kilos of weight when wet and full of mud. They proved difficult to clean out. So in the bin they went and the car is no louder than before. Next time you go and play remove the bash plates and feel the weight before and after removing the foam, you will be pleasantly surprised.
                Steve
                Lightforce 240Blitz driving lights, Rear hitch recovery point, GME tx3400 uhf, 64watt Uni-Solar cell, ARB CKMA12 Air compressor. all awaiting new vehicle to be delivered so they can be remounted.
                  Mick
                  Picutres as promised mate. I think you're spot on with your theory as I cannot see any other purpose for their existance.
                  As you can see by the blue arrow here on the close up, there is no shortage of sh!t and crud that builds up in here. If it's purely for NVH reasons, then it's getting ripped out when I get a chance, which is hopefully when I'm fitting some proper bash plates
                  All that build up of snot is still there after giving it a huge hosing when I got back from Loveday too, you just can't get rid of it!
                  AJ
                    Mmmm... rust magnet if you ask me.
                    Not fitted to Petrols or previous 1KZ diesel.
                    Mick
                      That's interesting. I just went and had a look at mine. They are there, but you have to look carefully to see them: don't look anything like the photo - they are thin, like furry tyvec or something. Mine haven't been dunked properly yet, maybe they swell when wet?
                      Anyway, I'd lose them. I can't imagine any useful function other than premature rusting.
                      Michael
                        I'd say in it's original state its the same sound proofing material that's on the bottom of the bonnet. Get it soaking wet a few times and add mud and it all turns to snot.
                        Mick
                          Those photos are not what is under mine. Mine is much thinner - probably only 3 - 4mm. Black on top and white (muddy orange) underneath.
                          I think I will toss them next time I remove the plates after off-road excursion.
