Rubber inner guard lining
  • Rubber inner guard lining
    hi guys and girls. I don’t suppose anyone has a template for the inner guards that I could print out.
    Thanks heaps
    Hi Travntor,
    You should have no problem finding pictures of the rubber guards on the internet that you can print out. Then you just need to confirm the size if not specified.
    If you can't find what you need I can help with the dimensions. I think I still have templates around somewhere that I can copy and post to you if you run out of options..
    Eddie
      As Eddie stated make up some templates, get yourself some generic push in fixings and reinforced sheet rubber.
      Then upgrade those plastic liners. Beauty is you can shape them better than originals.
      cheers
        I did this to the 150 today. I bought 3mm rubber insertion and it's too thick, suggest 1.5mm.
        The thicker rubber will cope better with stones etc but the plastic clips aren't suitable for that extra thickness.
        It's pretty easy to template from brown paper and transfer it to the rubber. Holes are then punched using a wad cutter.
        The actual shape can be seen from the remnants of the factory things, which on the 150 are just rubbish.
