Vibration when Braking
  • Vibration when Braking
    Guys
    I am experiencing a slight vibration in the Streering Wheel When I Press my Brakes , I notice it more when I am going at 80KM or so and press a mid-force brake (Not too hard and too soft)
    The dealer teels me it is some scouring on the pads and he will clean it on the next service - As usual I don't believe him :twisted: -
    Other Mates here experience the same , and the same idiot dealer told them it is the RIMS -they are not alloy - :P ha - will mine is and still I get this
    Any reason you can think off for this, did anyone of you experience this before
    Regards
    White VX LC120:2006
    Mansour,
    The dealer may be right, there are many reasons for brake vibration, brake pad resin build up is one but generally it is warped brake disc's that cause the vibration.
    Cheers, Fazza.
    07 Silver Ash, GXL, D4D, Auto. Lifestyle rear cargo rack. 2500 kg Tow bar with Tekonsha elec brake controller, Rear dust deflector, Mio Sat nav, (Still trying to fault the Dunlop AT20's)
      Thanks Fazza
      THanks Fazza
      I will check my scouring / built-up resine
      As for my mate who have the non-alloy wheels , he changed his discs and pads and drums with new ones but still experience this vibration :shock:
      Sounds ODD , I suggested that the tyres might be contributing to this but even his are new (he got 83K on his rig)
      Cheers Fazza
      White VX LC120:2006
        Sounds like glazing to me.
        Have them skimmed to clean them up and try some different (more aggressive) pads in them.
          tell your mate to check his tyres, I have seen a set of BFG all terrains that have been out of round, the rims etc were all blamed to start with but in the end it was the stinkin BFGs out of round :roll: same result as you mentioned.
            Brake Vibration
            Hi,
            I have not noticed this apart from braking on an un-even road like a speed-bump or a road with un-even tarmac. Infact apart from brake vibration i am also getting loss of braking.
            On a smooth surface braking is cool !
            Any takes ?
            Regards,
            Naukhez
              Had this same problem
              had the rotors machined and it fixed the problem
              Jonny
