Very unnerving experience when the brakes on my 2006 VX decided to pack it in. Was out and about yesterday and went home to drop some gear off before heading off again. Got to the first corner after leaving my place, eased on the brakes as normal but felt very little resistance in the pedal. The car hadn't slowed and cornered a little quickly. I let the car roll on and tried to brake again and got nothing.
I managed to turn around and get back home, driving quite gently. Once parked I realised I could quite easily push the pedal right to the floor. No difference whether the engine was running or not. Brake fluid reservoir was full so that wasn't the issue. Couldn't see anything obviously wrong around their either. It happened quite suddenly as there was no sign of something happening before that.
Got an ex-mechanic mate to come round today and check it. Started to do some elimination so checked the lines to each wheel, Checked the pedal set up, gave it a quick bleed etc. Nothing seemed amiss there and couldn't find the source of the problem.
Clearly I cannot drive it anywhere so will need it towed to get it fixed. Not sure whether to take it to a Toyota dealer or to a brake specialist. Was going to make calls to each and get feedback before deciding who is most likely to fix the problem.
Does anybody have an idea what the issue could be?
