I've installed Bendix 4WD brake pads due the amount of dirt road and outback driving we do with a caravan in tow, and they are a much better feel than the OEM pads, and I hope they last longer.......we'll see
Bendix 4WD Pads
My D4D has just had a brake pad change. Removed the OEM pads after 95,000 kms. Still some pad left. The brakes where pretty good but after replacement with Bendix 4x4 pads all round the brakes went to sensational. Very happy with the new pads, excepting for a brief squeal when first touching the peddle. No idea what can cause this noise. Anyone ever found this problem?Shifter.
2007, GXL, D4D Auto, Racor 230 filter with 10 mic (98%) cartridge,
Normally a chamfer just on the edges of the pads before fitting them will stop that annoying squeal. Its just the very outer edge of the pads touching the face of the disc rotor before the full face of the pad. I have been using bendix in all cars/4wd's for years. The original pads are shocking for brake dust so you will notice a big difference there as well. I'm going to replace in the 120 (still factory pads 130k) but also fit slotted rotors as well. I was told replacing brake lines with braided ones also helps as the original ones bulge out under pressure but I'm not going the bother with brake lines......Cheers SteveFace lift 150 Prado V6 auto. No mods yet
On the 120 I went for bendix pads and DBA rotors and it was a marked improvement in braking and feel. When the time comes on the 150 I will be doing the same thing.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Just an update on my experience with these. After several 1000km I noticed that sometimes they need to get some heat into them before they work 100% - looking on the net, I'm not the only one to have found this. It didn't stop me from fitting them on the rear as well.95 3.0 Camp Car, 150 V6 Daily Driver[SIZE=4]
[/SIZE]
Originally posted by Shifter View PostMy D4D has just had a brake pad change. Removed the OEM pads after 95,000 kms. Still some pad left. The brakes where pretty good but after replacement with Bendix 4x4 pads all round the brakes went to sensational. Very happy with the new pads, excepting for a brief squeal when first touching the peddle. No idea what can cause this noise. Anyone ever found this problem?[SIZE=2]120 GXL D4D Auto, with a 'List of Wants' greater than the 'List of Needs' greater than the 'List of Haves'
Originally posted by Steve M View PostNormally a chamfer just on the edges of the pads before fitting them will stop that annoying squeal. Its just the very outer edge of the pads touching the face of the disc rotor before the full face of the pad. I have been using bendix in all cars/4wd's for years. The original pads are shocking for brake dust so you will notice a big difference there as well. I'm going to replace in the 120 (still factory pads 130k) but also fit slotted rotors as well. I was told replacing brake lines with braided ones also helps as the original ones bulge out under pressure but I'm not going the bother with brake lines......Cheers Steve
Could you point me in the direction of the right parts please. This aint my area. Also interested in the braided lines you refer to chief.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
MLC my mechanic told me about the chamfering of the edge of the pads as my first 90 series was bad for that initial squeal when first dabbing the brake pedal. The braided lines I have no idea where you would purchase them as I never bothered to look into it as I don't intend changing them over but I have read that on here and other forums in regards to giving better pedal pressure.... Disc rotors I'm just buying from my local brake n clutch shop here in penrith slotted only not drilled and slotted... Cheers SteveFace lift 150 Prado V6 auto. No mods yet
Toyota refused to rectify under warranty but the dealer was happy to sicaflex the pads to the pistons or to that affect as their diagnostic was the calliper vibrates at a fast rate causing the squealing sound.
I just put up with it and pump the pedal that usually stops it but as I said it's getting a little worse as time goes on.
Maybe I should chamfer the pads.
HazzaSilver 120 Series Diesel GXL 2009 with Option Pack 2, king Springs 2" Lift with 'H' front spring, MT ATZ 4-RIB, Dual Battery, Deluxe ARB Bull-bar, Winch, Towbar, Anderson 50 amp plug at the rear, Weather Shields, Bonnet and Head Light Protectors, Rubber Mats inc Cargo mat, UHF Ariel, Portable Uniden UHF plugs into areal, On-board ARB Compressor, Brains Black Box TG150 Protector, Rear Black Duck Seat Covers.
I doubt there will be any gain from braided lines but if you decide to go that way make sure you get ADR approved lines.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by mjrandom View PostI doubt there will be any gain from braided lines but if you decide to go that way make sure you get ADR approved lines.
Aint no gonna look for no rat-tinzzs, I'm is one bad mofo and "livin on-da-edge". You wit me on this, know wat I'm saying bro.
tru dat.
mlc- getting jiggy wit it.
PS, ok, mjr, not needing them, just considering.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
