clicking in reverse
  • clicking in reverse
    Just got a 2006 Turbo diesel GXL auto and I notice that when I reverse and put the brakes on rather than ease them on theres a click that comes from the front end..is this normal?
    Also where the F#@* do you mount a CB radio without going ops: to the expense of a console..or is a 5 watt handheld just as good
    i get the click too.
    as for uhf..
    there are plenty of threads about it if you use the search function
    and here is my uhf mount
    its a gme tx3400.
    2004 GXL V6 5 speed auto. Cooper STTs, 40mm Lift, Scanguage II, Flyer batterybox, GME3400 UHF, Engel 40L, Safari Snorkel, IPF Xeon Headlight upgrade, Milford Cargo Barrier.
    [img]http://users.on.net/matthewv/4wd/prado.jpg[/img]
      thanks just checked few installations..wasn't using the right terminology..DER...had CD in my head not CB.
      so you reckon the clicks nothing?
        The front pads are held in with pins and when you change direction and tap the brakes they move on the pins. Normally only once per direction change. As in going forwards they get pulled up inside the caliper and then if you go backwards they get pulled downwards and the click is the pads moving on the pins. It is normal for most multi-piston brake calipers to do this.
        Matt
