Brake Pedal Vibration
    Pedro,
    Good to hear all is well again, sounds to me that you may have had a earth problem. (Black wire??)
    Reading between the lines, I would also suggest that the brake vibration was not the wiring but the caravan brakes?
    (I would think that if it was a wiring problem the brakes would either work or not work)
    You mentioned earlier about work to be carried out on caravan brakes???
    But all is well that ends well :wink:
    Fazza
    07 Silver Ash, GXL, D4D, Auto. Lifestyle rear cargo rack. 2500 kg Tow bar with Tekonsha elec brake controller, Rear dust deflector, Mio Sat nav, (Still trying to fault the Dunlop AT20's)
      Fazza,
      Thanks for your comments.
      The "earth" was one of the many words used, but I thought it was the wire to the fridge in van , though mention was made of earth.
      So I guess I will need to ascertain what pin 2 in socket is for. The black wire on caravan plug was to fridge and I took it that this must match up with pin 2 in socket.
      Maybe some sparkie can comment on this.
      It may have been brakes on van though they were not changed and it was towed by one of the repair shop cars with Prodigy and no problem.
      I think the narrow wire originally fitted was not getting the oomph to van brakes.
      Pedro
      Pedro
      2007 D4D Auto
