gday would really appreciate some help with this problem. my ABS VSC TRC VSC OFF lights are all staying on to put the car into drive i have to press the shiftlock button after which it drives fine but the abs does not work. we have had this problem before but if we just hit the brake pedal hard a couple of time it would go away. also the brake lights are not working at all, all the other lights are i have checked the globes they all look fine but i am going to replace them now. i have also checked the fuses and found no problem.. really need help please thanks Brad
help with abs and no brake lights
Re: help with abs and no brake lights
Hi Bradbrick,Originally posted by bradbrickgday would really appreciate some help with this problem. my ABS VSC TRC VSC OFF lights are all staying on to put the car into drive i have to press the shiftlock button after which it drives fine but the abs does not work. we have had this problem before but if we just hit the brake pedal hard a couple of time it would go away. also the brake lights are not working at all, all the other lights are i have checked the globes they all look fine but i am going to replace them now. i have also checked the fuses and found no problem.. really need help please thanks Brad
It sounds serious, if you have done all the normal checks, fuses, abs harness connector secure and dry (RHS engine bay), wheel sensors wiring harness checked for damage then I would take the truck to a local Toyota dealership ASAP.07 Upgrade GXL D4D, Manual, Dune,Sov Bar, BFG's, SG11, Redark dual Batts, Extensive Aux wiring, Stebel, LED stop tails, IPF HID's (my mod), 240V Inv, ARB Comp, GME UHF,TPMS, Safari snorkel, GPS,Hilux washers, 40l Engel in 30% pas pos,homemade A/C cond protection plate, polyairs.
just pulled the switch apart and gave it a little squirt with rp7, pluged it in to test and all is working well the abs etc lights have gone and the brake lights are all working so obviously the contacts in the switch were abit dirty. very pleased to have solved the problem myself can only imagine what the dealer would have charged me. i hope this helps others, goodluck
Brad
Well there you go, well done, its great when a simple fix works out.Originally posted by bradbrickjust pulled the switch apart and gave it a little squirt with rp7, pluged it in to test and all is working well the abs etc lights have gone and the brake lights are all working so obviously the contacts in the switch were abit dirty. very pleased to have solved the problem myself can only imagine what the dealer would have charged me. i hope this helps others, goodluck
Brad
