My 2005 Prado GXL has recently developed a knock in the front end somewhere. The sound is like hitting the disc brake with a hammer and only occurs once. It usually happens after the vehicle has been standing for a bit and usually when reversing and after moving only a metre or two and immediately after touching the brake. It's a bit hard to explain exactly. I had a service today and the mechanic checked all the suspension bolts, springs, shockers etc, but noticed the brake pads have a small amount of play in the pins that hold the pads in place. There are marks on the edge of the pads which indicate that it might be the cause. The vehicle has done 110,000 kms and still on the original brake pads.
Has anyone had something similar on their Prado? I would welcome your thoughts.
