Hi guys,
i dont know what all this (thingy) called, i didnt notice something related in the list their, so i started new thread..
well, I have an issue with my 4x4 gear. As everyone know, the gear is always on H, when u do safari drive u either put it on HL or LL.
Since a year now, I'm facing a problem (even though I went to a garage and he changed one piece from inside the gear box and said it was damaged).
i still facing the same problem even after changing the damaged part, my issue is when I put the gear on HL, while driving on sand suddenly the main gear turn from Drive to Neutral even though it's on D not N and the 4x4 gear jam and don’t move, and I can't drive, when i put the transmission on N and press on accelerate "to shake the gear box" sometimes after shaking the 4x4 gear moves and sometimes it don't.
first time ever this issue happened, every one told me its an electrical problem, and by chance i have an electrical problem that days so i changed the dynamo after checking it and found out that the output electric is not enough, after changing the dynamo i didnt drive on extreme safari routes, i did only easy ones and it was fine, last weekend i went on extreme route and faced the problem again but i was lucky that the gear moved after shaking it and went back to D..
did any one face this problem? how did u fix it?
now i'm thinking to change the full gearbox, it will cost me about 1360 USD
the most important thing, i hope every one understand what i mean
regards..
saif
regards..
saif
