Hi,
Just looking for a possible solution.
I Have a Prado 120 2003 5 spd manual V6, with a 2inch TJM Lift with under 200,000.00 Klms (Medium Front and Rear Springs) which has started to make a humming noise in 4th gear at about 60 k's per hour and then also in 5th at about 90 k's per hour.
I have changed all of the transmission oils within spec + added some Nulon G 70 (Old oil had no sign of shavings etc.), also the inner and outer front cv boots have been replaced and re-greased and the noise is still there. (Seems to be coming from the front with slight vibration through the floor)
Has Anyone had the same issue and can give me an idea of the what the problem may be?
Is it worth taking it to Pedders for a 28 point inspection or do you know someone in Brissy that could take a look?
Also a mate said instead of running 80-90 in the front diff upgrade the both diffs to LSD 140 is that possible?
Sorry to be a pain, but just looking for a possible solution.
Wombat1
Wombat1
