120 D4D 6spd man gear stick excessive play
  • 120 D4D 6spd man gear stick excessive play
    Hello prado guru's!!
    My first time on here so thank you in advance.
    The question i have is regarding the excessive play in the top half of my two part gear stick. I have had a look after removing the panels ect and the bottom half has minimal to zero play in it. There is a rubber looking bush that is below the top half of the gear stick which I asumed should be up inside?.
    Has anyone fixed this issue themselves?
    Thanks again
    I think it might be the same as this one
    http://www.pradopoint.com/showthread...120-series-D4D
      Thanks amts!
      I have read this one and it definitely gave me a lot more insight. I am still wondering if you can disassemble the two parts and repair the internals of the top half..?
      Cheers 👍
