extended drive shafts
  • extended drive shafts
    hey guys , just spoke to a CV rep at the Burson's show for clipsal last night about extended drive shafts for the Prado 120/150
    he called back this morning to say they were in already and the part number is CVS.1165L
    they already had them for the hilux and have added the others in the range from Toyota
    could be a handy fix for the lifted unit out there to stop the binding at full droop
    James
    James
    Hey James,
    Sounds interesting!
    Did they tell you how much angle they will droop to before binding?
    Unfortunately for the Prado IFS, you'll bind the OEM rack end at the same time as the OEM CV, so you will still be limited to the 585-590mm open length. After market rack ends also bind up the same as OEM angles, so that won't help either.
    Best
    Mark
