Auto Shift Lever Broken
  • Auto Shift Lever Broken
    Hi all,
    I have an 05 auto diesel. Last week I was changing down manually (towing) and the lever got jammed between 2nd & 1st.
    When I moved off I found that there was no more detent between D and 3. It's still spring loaded to D but I have to hold it in 3.
    I've dismantled the unit and located a steel pin about 20mm long, which I refitted next to the lever. The problem is that the detent is back, but it jams again between 2 and 1.
    Does anybody have an exploded diagram of the shift lever assembly? I've searched high and low for any loose parts but haven't found any.
    Thanks in advance.
    [i]I remember when sex was safe, and flying was dangerous![/i]
    we had this happen about 3-5 months ago.
    lived with for a little bit, but was covered by warranty and replaced.
    now notcher than before but you get that.
    [url=http://www.fuelly.com/driver/damonat/prado][img]http://www.fuelly.com/smallsig-metric/50578.png[/img][/url]
      I had the same thing happen about a month ago. I found out the plastic part that houses the metal 'bullet' had cracked on one side and the 'bullet' kept falling out. I tracked down a wrecked prado and butchered a gear selector assy to get the part I needed. Now working correctly. You need to find out what exactly is causing your problem.
      Costs to replace with genuine parts:
      Selector assy without top selector plate and electronic module- $290
      Selector assy with top selector plate and electronic module (can't get the top selector plate without the electronic module) - $900
      Selector assy with top selector plate and electronic modue from wreckers (a bit damaged) - $25.
      Geoff...
      NOT LOST. EXPLORING!
      04 GXL V6 Auto. ARB Deluxe Winch Bar, OME 2" Lift, Dual Batteries (Redarc), Warn XD9000 Winch, Safari Snorkel, Custom Drawers & Sliders, Rear ARB Air Locker, GME TX3200, Rhino Racks, Kaymar Rear Bar (with Jerry Can Holders & Spare Wheel), Polaris Awning, Waeco 35l & 50l Fridges, K&N Air Filter, Washer Upgrade, Firestone Air Bags, Trackabout Camper Trailer.
        Thanks very much for the info gents!
        Geoff the plastic holder on the side of the gearstick is cracked as yours was. Why it happened is beyond me! There was plenty of grease on all the sliding parts.
          Re:
          My shifter is now broken as it wont stay in third.
          Ive tried many wreckers and it seems very hard to source a 4 speed shifter.I might have to go into it and take a look to see exactly whats going on.
          Has anyone got some info/photos of how they took the shifter mechenism apart to find the problem.Thanks
          White 2003 V6 GXL, 4spd auto, Vapor injected LPG, Autocraft Prem Billstein 2inch lift with poly air-bags
