Front end driveline rattle under load **Sound file added**
    Hi crammy,
    I just listened to the file, it sounds like mine in the clifton beach or CBH car parks which are great spots to listen to your own vehicle driveline with windows down in 1st gear.
    These Manual constant 4wd Prados make a fair racket, when compared with my previous vehicles.
    My sounds are geartrain/drivenline backlash due to loading up/ unloading between the torsen dif and front and rear diffs,with a little bit of gearbox rattle included, gets even more noisy when you turn a corner on a slight rise or decline which makes sense.
    Owe and to add to the cacaphony a bit of Low Load "Meaty" D4D noise thrown in.
    Sorry if it sounds a bit double dutch mate just my thoughts
      Originally posted by clifton
      Hi crammy,
      Hey Clifton thanks for your thoughts.
      The funny thing is that it never sounded this bad until I came back from the cape. That trip sure did test the poor old girl out! I've also noticed my thrust bearing is noisy at times, I wonder if this has anything to do with it? I think it got damaged going through lakefield NP after some pretty hairy corrigations and bulldust. When we pulled up it was bloody noisy, but then quitend down over the next couple of days.
      Crammy
      2008 GXL M6 D4D, Silver
      Build Up---> [url]http://www.pradopoint.com/viewtopic.php?t=2315[/url]
      [b]{[/b]ATS Ridepro/Bilstein Lift[b]}[/b] [b]{[/b]Dual Batteries with RanOx Battery Booster[b]}[/b] [b]{[/b]600w Projecta 240v Inverter[b]}[/b] [b]{[/b]Dunlop AT3's / MT MTZ's on Speedy Grande Rims[b]}[/b] [b]{[/b]ARB Deluxe Winch Bar[b]}[/b] [b]{[/b]IPF900XS Spotties - Converted to 50w 4300k HID[b]}[/b] [b]{[/b]35w H4-3 4300k HID Hi-Lo Conversion[b]}[/b] [b]{[/b]ARB Underbonnet Compressor[b]}[/b] [b]{[/b]GME TX3440[b]}[/b] [b]{[/b]T-Max 10,000lb winch[b]}[/b] [b]{[/b]Safari Snorkel[b]}[/b] [b]{[/b]Milford Cargo Barrier[b]}[/b] [b]{[/b]Rhino HD Roofies & AT1410 Roof Tray[b]}[/b] [b]{[/b]60L Waeco[b]}[/b]
      [img]http://www.gifs.net/Animation11/Transportation/Cars/4_wheel_drive.gif[/img]
        Hi Crammy,
        That trip should not worry your clutch throwout bearing, but I do believe they are a little noisy in these trucks, I think a few members had some issues a while back with failed Clutch Thrust bearings.
        I think we need to do a comparo soon as I have just recieved another Dealership Toyota survey form to complete.
          Re: Front end driveline rattle under load **Sound file added**
          2007 Man same noise as the sound file. I am certain it happens after a 100kph+ long trip, my thought was the oil thinned out, too warm? Did it from new, hope we aren't looking at premature transmission death. Toyota please respond! Do they need to improve cooling?
