Clutch failure
  • #31
    Re: Clutch failure
    Originally posted by weasal4x4
    Being my first 4wd, how many km's can you expect to get out of a clutch? (I realise it would depend on wear and tear). I've just hit the 100,000 in an 06 GXL and toyota tell me i have a couple of thousand km's left on it. The smell is noticeable when towing the camper trailer from a hill start.
    Hi weasal4x4,
    I have averaged 140,000km,s out of my last three 4wd's clutch pressure plates, my last two tojo,s had noisy throw-out bearings when compared to my GU Pootrol, I had to replace the Hilux forerunner clutch throw-out bearing at 90,000km's it was as noisy as my current 07 Prado with 34,000km,s on the clock, I recently had the Prado inspected by our local dealer who said it was O.K.
    • #32
      Re: Clutch failure
      Thanks Clifton, I guess i'll have to look at something a little heavier duty as i don't want to be replacing clutches every few years.
      [INDENT][CENTER][SIZE=4][B][URL="http://pradopointgtg.org"][COLOR=#000080]PradoPoint GTG 2014 - [I]Iconic High Country - Victoria[/I][/COLOR][/URL][/B][/SIZE][/CENTER]
      [CENTER][SIZE=3]Big Thanks to Our Sponsors - [/SIZE][SIZE=4][COLOR=#ff0000]ARB 4x4[/COLOR], [COLOR=#800080]Dobinsons Springs and Suspension[/COLOR], BCF, [COLOR=#008080]Terrain Tamer[/COLOR], [COLOR=#696969]ORU[/COLOR], [/SIZE][SIZE=4][COLOR=#ff8c00]Maxtrax[/COLOR], [COLOR=#0000ff]Traxrax[/COLOR], [COLOR=#800080]Brains[/COLOR], [COLOR=#ff0000]Redarc[/COLOR], [COLOR=#008000]Opposite Lock[COLOR=#222222], [/COLOR][COLOR=#0000ff]Kaymar, [/COLOR][/COLOR][COLOR=#ffa500]Hema Maps, [/COLOR][COLOR=#ee82ee]pure-sense, [/COLOR][COLOR=#696969]Bushskinz, [/COLOR][COLOR=#ff0000]Piranha Offroad [/COLOR][COLOR=#800080]High Country 4x4 [/COLOR][COLOR=#222222]& [/COLOR][COLOR=#808080]Century Batteries.[/COLOR][/SIZE][/CENTER]
      [/INDENT]
      • #33
        Re: Clutch failure
        Hi Weasel 4x4,
        Yeah I know how you feel, Crammy tried to get a heavy duty clutch for his 120 but alas none were available, as much as I hate automatics and the bad driving habits they produce in some motorists :x , modern auto transmissions units with pre-select etc. are the go for long term reliability and manual transmissions seem to be going the way USA manual transmissions did., sorry to get of subject a bit.
        • #34
          Re: Clutch failure
          Yesterday I noticed clutch slippage in my 2005 6sp Man 120series while trying to reverse my toy boat up the driveway. I've reversed it up the drive a dozen times before with no dramas. The clock has just ticked over 151000kms. I'd hate to have clutch failure while trying to retrieve my boat from the water, so can anyone suggest a heavy duty clutch and a reputable dealer/shop in brisbane? I would like to get it done in the next week or so.
          Regards,
          Wags
          2005 GXL V6 4.0l, ARB Deluxe winch bar, Lightforce 240 Blitz spotties, Uniden uh015sx UHF, Wind Cheetah 2.2m roof rack, Pro Comp All Terrain 265/70/R17, 2" lift from King Springs and Bilstien Shocks, Waeco CF-50, Warn Magnum winch, Dual batteries.
          • #35
            Re: Clutch failure
            I was quoted $1750 fitted for an Exedy Tuff clutch and have been quoted $1600 fitted for a custom made one. Both are nearly the same in strength, but will go with the custom clutch.
            • #36
              Re: Clutch failure
              I'm in Melbourne , but haven't started looking around yet. I'll post some prices when i get them.
              [/INDENT]
              • #37
                Re: Clutch failure
                i had my new clutch installed today, ended up getting the exedy safari tuff and wow what a difference over the old clutch, pedal pressure is a little more then std but not much, i had 132000k on the clock, $1750 for a clutch install wags, that steep, i got clutch done, including flywheel machine, new oil in transfer, and gearbox, rear diff oil changed and hand brake adjusted for $1500 neat, i would be n the blower to a few more places wags. cheers samo
                • #38
                  Re: Clutch failure
                  Finally got organised and was quoted about $1950 fitted from toyota for a standard clutch but ended up getting a heavy duty Clutch Industries clutch fitted and fly wheel machined e.t.c for $1500. Picked up the car today and i reckon the pedal is alot lighter than original. (but i haven't driven a manual for over a week). The clutch kit it's self was $840.
                  [/INDENT]
                  • #39
                    Re: Clutch failure
                    good to see ya got the clutch problem sorted weasel, $1500 is not a bad price at all, better than $1950 for the std toyota clutch, mine takes up about an inch of the floor and takes a bit of gettin used to, and $840 is a good price, thats about what i paid for the safari. cheers samo
                    • #40
                      Re: Clutch failure
                      what ever happened to the fair trades complaint....?
                      07 Upgrade GXL D4D, Manual, 6 Speed, ARB Deluxe Bull Bar ,Mickey Thompson MTZ's ,ARB Dual Battery setup,Extensive Aux wiring, Autocraft Rock Sliders, Narva Blue 225's, 240V Inverter, ARB Underbonnet Compressor, GME UHF, Safari snorkel, Navway GPS, Ozexplorer, Hilux washers, 60lt Engel, Blackwidow Storage System, Foxwing Awning, ARB Roof Rack, Underbonnet Shower System, Autocraft Bilstein / Ridepro Suspension, Brown Davis Underbody Protection, Rear Camping Spot Lights, Tigerz II Winch.
                      Latest Mods: Venture Shield Body Protection, HiLux Washers
