CV Boots
  • CV Boots
    Well i put up a post about heavy duty CV boots in the 90 series but i didn't get any help. I'm not to sure if they run the same as the 120 series but someone might know something that could help me. I have torn my second CV boot in 10,000km actually put a stick through it, and i am wondering if there are heavy duty boots available. Any help will be appreciated.
    02 gxl locked and lifted
    Re: CV Boots
    Check out this web site.
    Posted on it. Read ALL The Porche one may work and be heavy duty...if you have a lift kit installed you may want to consider spacers too...even if you have on a 50mm lift.
    Regards,
    Karrathprado
    I have the same problem and am thinking about installing a differential drop or whats called a differential spacer kit which changes the angel of the differential. Also Toyota has a heavy duty boot that they sell for 100$ or I found on Tundra Solutions.com website that Porche 930 cv boot works well to. I found one on Ebay for 30$ for a set of 4. I am still doing research on this for myself. Write me on the TS website my user name is earwig and I will keep you posted to what I did and how well it worked.
    http://www.faqs.org/qa/qa-20998.html
