All
I have an Oct 08 build Jan 09 plated GXL auto Prado and I seem to have some play in the drive shaft. It is my first auto, so perhaps it is normal. If I put it in second and drive at ~2000rpm and go on and off the throttle, when it goes from accelerating to engine braking there is a thump. Go from braking to acceleration it happens again. I imagine it would happen if there was play between the gears or something. It is like the tail shaft thump that has been wideltt reported (which I also had, and had it regreased). Had the dealer look at it an they said it was normal. It can also occur when the box changes up a gear and you take your foot off the accelerator pedal.
Is it normal? Or should I persue the dealer for a fix.
Ta in advance
Perth_GXL
Ta in advance
Perth_GXL
