Loose gear stick in 5 speed auto
  • Loose gear stick in 5 speed auto
    Hi,
    My gear stick in my 2005 auto has suddenly come very loose and no longer clicks into park or into manual mode. Eg. if I drop into D auto I used to have to push the lever to the right and it would then click into manual 4th (I think). From there you could pull straight down to 3rd, and then to get into 2nd you push the lever again to the left. While changing gears manually off-road the gear stick suddenly became loose. I'm no longer able to go into manual 4th, it just flops back to "D" auto and no longer have to push the lever to the left to get it into park, it just sort of goes straight up and stays there. The gears seem to change ok.
    If anyone can shed light on this problem I'd be most grateful.
    Thanks in advance.
    Ausa.
    4LV6, OME suspension, Poly Air's, ARB bull bar, Rhino Rack alloy tray, Coopers, Magnum Winch
    Re: Loose gear stick in 5 speed auto
    There are a few threads that may be able to help on this have a look at the 120 drive train section
    viewtopic.php?f=10&t=3786
    is an example
    Neil
    White 2013 GXL 79 series dual cab, ARB GVM Upgrade, ARB Delux winch bar and scrub bars, GME TX3440 and much more to come
      Thanks Neil. Looks like the same issue. At least I now have some idea of the problem.
      Ausa
