Guys,,the other day i got half way up a sand dune and could not get any further, when i checked the wheels i noticed that they were not spinning no matter how much boot i gave it, I was not bellied out and i tried the same hill in low range ,same result.I put it into reverse and went back down the dune.I have an auto transmission and wondered if that could be causing the problem.ANY IDEAS WOULD BE WELCOME cheers
Wheels not spinning
Re: WHEELS NOT SPINNING
hey Chugger, did you only look at the drivers side wheels, if the passenger side wheels had no traction they would spin and the drivers side would do nuthin. this situation is easily rectified with a couple of diff lockers.
