Auto trans failure. No reverse and stuck in 1st
  • Auto trans failure. No reverse and stuck in 1st
    2007 Prado Gxl Turbo Diesel. While doing some 4wding in sand. Engaged low range and selected reverse to exit a bog and nothing, acted as if in neautral. Stuck it in drive and drove out of the sand but transmission did not want to leave 1st gear. After getting back to the road and returning to standard high range mode, still no reverse and very hesitant to change out of first gear. When it changes out of first at high revs (3500rpm) it jolts straight in to 4th gear and then wants to drop back to first. Any Ideas ?? Stuck in Broome until we can find a solution.
    Cheers, Tim
    Hey Tim.
    Is there any lights staying on the dash? Eng light?
    Have you tried selecting the gears manually? IE: L,2,3 and so on.
      Hi Greeny
      No lights on the dash. I can select L manually, then second and it will reluctantly clunk into gear, when I select 3rd it acts as if in neautral. It will sit in 4th ok if the speed is over 40kms.
        Could be the selector assembly is knackered. I had to replace mine in Darwin last year (2005 Grande), cost about $1100 and had to be shipped up from Sydney.
          If your able to, remove the big electrical plug off the side of the transmission and see if it changes gears ‘normally’
          this way you’ll eliminate if it’s an electrical of mechanical problem with the trans.
