ARB Air locker versus TJM Pro Locker
  • ARB Air locker versus TJM Pro Locker
    Hi All
    Am looking at fitting a rear air locker 2005 GXL, can you shed some light on the ARB versus the TJM air locker, what are the pro's and cons of each, and what do they cost.
    lockers
    Hi Frank,
    I've had ARB lockers in my last two cars (hiluxes) and found them to be great Not sure about the activation on the TJM product is it an air compressor? With the air locker your getting the bonus of an air compressor, cost was about $1800 for the rear and a few hundred less for the front locker as the air compressor was installed with the rear locker. Another point to consider is why put it in the back? put it up the front that way you will have rear LSD and front locker, ie you will get more traction for your dollar. or go all out and get front and rear, but this will cost you over $3000.
    07 D4D Man, Arb Bar, Warn winch, OME 2inch, Snorkel, IPF's, dual Batts, Cargo barrier, MTR's, 60L engel, ARB touringroof rack and tent, front and rear air lockers.
      If the advertising is correct then the prolocker is a technically better solution than the airlocker.
      Ive recently had one fitted to the rear (after a long wait), but havent really been able to use it yet... I will in a couple of weeks during our cape york trip
      I never liked the idea that the arb lockers could leak oil through the air line, the tjm design doesnt have this issue.
      I guess only time will tell...
      I already had a black ox compressor all that was required was a conversion kit to add the air resevoir . The black ox is a much more hard core compressor than the dinky arb underbonnet one ;-)
      BTW, tjm will bring out a front locker. now that ARB has they have no choice
        Hi all
        I not sure how they fit them but can you have a locker and keep the limited slip feature?
        Same dif modified with locker.
        What about detroit lockers, Are they any good.
        My limited slip is very limited when one wheel leaves the ground,which sort of defeats the purpose,What I need is more suspention travel and a lock dif.
        2003 GXL Turbo Diesel,
          Originally posted by Russ WA
          Hi all, I not sure how they fit them but can you have a locker and keep the limited slip feature?
          G'day Russ,
          Fitting a locker involves replacing the internals to the diff, replacing the LSD function. There's a fairly good description on the ARB website.
          Drew.
          2005 Toyota LandCruiser GRJ120R Prado "Pilbara" (GX+) Petrol V6 5 Speed Auto, ARB AirLocker rear diff locker, Safari Snorkel, Bilstein Shocks, OME 2" Lifted Springs, PolyAir airbags, bash plates, Icom HF Transceiver, Uniden UHF CB, HID and LED lights, Black Duck seat covers, Tekonsha Prodigy trailer brake controller, Redarc Dual Battery Controller, ATS4X4 Side Steps/Rock Sliders.
            Are they doing the pro locker for the front diff in the 120 Prado yet?
            2007 D4D auto, Tunit Power Module, Scan GaugeII, Bilsteins & lovels HD, raised 50mm front & 60mm rear, 10,000lb Tmax winch, 7/16th Amsteelblue synthetic 23,000lb winch cable, TiTan HD winch solenoid pack, Outback draws with fridge slide & 50 litre Waeco, Ryno roof rack & Alloy Cage & extra set of Rhino HD Roof bars x 3, TJM type 15 steel Bullbar powder coated silver, Dual battery setup with custom tray, Bosch Navigator spots with 55w HID kit, Sand Grabber mats, Toyota Tow Bar, Sensor Touch Electric Brakes, Cooper ST 265/70/17 tyres, Uniden remote head UHF radio, Modified Milford Cargo Barrier, Extra power points in the back run with 10mm wire for fridge & inverter, Anderson plugs with 10mm wire front & back for the camper & compresor conections. 7 inch in dash JVC DVD player with bluetooth & Ipod adaptor, 39DB Stebel High Power TM80/2 Magnum Electric Horns. JL Audio 300/4, 300/2 power amps, Pioneer TS-C160R front splits & TS-D161S rear speakers & 12" Pioneer sub
            Still need to fit some heavy duty engine & transmision gaurds, snorkel. 9inch headrest monitors
              Pradogxlv6, How does the pricing compare between ARB & TJM?
              2008 GXL M6 D4D, Silver
              Build Up---> [url]http://www.pradopoint.com/viewtopic.php?t=2315[/url]
              [b]{[/b]ATS Ridepro/Bilstein Lift[b]}[/b] [b]{[/b]Dual Batteries with RanOx Battery Booster[b]}[/b] [b]{[/b]600w Projecta 240v Inverter[b]}[/b] [b]{[/b]Dunlop AT3's / MT MTZ's on Speedy Grande Rims[b]}[/b] [b]{[/b]ARB Deluxe Winch Bar[b]}[/b] [b]{[/b]IPF900XS Spotties - Converted to 50w 4300k HID[b]}[/b] [b]{[/b]35w H4-3 4300k HID Hi-Lo Conversion[b]}[/b] [b]{[/b]ARB Underbonnet Compressor[b]}[/b] [b]{[/b]GME TX3440[b]}[/b] [b]{[/b]T-Max 10,000lb winch[b]}[/b] [b]{[/b]Safari Snorkel[b]}[/b] [b]{[/b]Milford Cargo Barrier[b]}[/b] [b]{[/b]Rhino HD Roofies & AT1410 Roof Tray[b]}[/b] [b]{[/b]60L Waeco[b]}[/b]
              [img]http://www.gifs.net/Animation11/Transportation/Cars/4_wheel_drive.gif[/img]
                I enquired on the price difference approximately 18 months ago. it was 2500g for 1 tjm locker Vs 1900 for 1 ARB locker. The front locker usually cost more than the rear. With twin TJM lockers fitted cost close to 4500 and for twin ARB fitted, 3500.
                  I run a ARB in the rear of the Lux and have given it a hard time after purchasing it secondhand. I have had none of the oil leak or seal dramas you hear of, I will be putting them in the Prado for me the TJM still has to prove itself and I am yet to find a local dealer I am happy with.
                  [color=#BF0000]Trail Toy - TJ Wrangler with some mods and some bling
                  Wifes Daily and Tourer - V6 120 Prado, some mods wife wont give me the keys.[/color]
                    the TJM locker has been around for years.
                    It is basicly a jackmac locker. far better design than the arb one.
                    Michael.
                      But the price difference!! :shock: Just my opinion and no, I haven't afforded either.
                      Matt
