how to drian auto transmition oil ?
  • how to drian auto transmition oil ?
    hi
    i want to completly drain my 5 speed auto transmition , any one done this before?
    reason ,when i got my prado second hand it was 166,000 Km , and apart from overall service i done was replacing the tran. oil but mistakly i changed the oil with TOYOTA type IV instead of type WS.(any way we don't have type WS here in Egypt)
    then when i tryed the car over the sand dunes the oil temprature light went on? so after searching the topic i decided to upgrade my trans. oil cooler with bigger one and ordered the WS oil .,the parts arrived today , and i want to make sure i flushed as much oil as i can without removing the oil pan as this will result to change the oilpan gasket .
    any ideas ?
    thanks
    Hisham
    [COLOR=blue]2006 VX ,5 Auto , currently Scan gauge II , Bonnet Guard ,wind deflectors,head lamp cover, dust deflector,insect net , Engel fridge,IPF fat boy,Hella FF300 lights,Toyota HD bars,BF 265/70 R17 A/T, Hella TPMS, K&N,OME 2",DBA , AirLift 1000 & Wirless Air control , ARB Comp,Safari Snorkel.[/COLOR]
    [URL="http://www.fuelly.com/driver/hisham/prado"][img]http://www.fuelly.com/smallsig-metric/52690.png[/img][/URL]
    Re: how to drian auto transmition oil ?
    I understand that the is an ECU update or similar to fix the issue of the overtemp light - not sure if it changes the point the light comes on or if it changes the auto's behaviour to lower the temperature...
    Have a search here on Pradopoint for similar topics....
    Richard
    2011 GXL TD Auto Prado Silver
      most dealerships now have a changing station.
      this makes it difficult for owners to do this.
      with those KM's you might be best to remove trans sump and change the transmission filter at the same time.
        most propably that i will do , will let you know the result.
        hisham
