New Scangauge x4.02 supplied AMPLE OUTDOORS LITHGOW
  • #76
    just ordered my scangauge II, From Ample Outdoors....back in stock, cost $169 + postage.
    hope to receive it soon & get it installed asap
    Steve J
    D4D 09 OME Suspension/ARB Winchbar/Safari Snorkel/IPF Spotties/Cooper ST Maxx Tyres/9000LB Tigerz11 Winch with Dynema Rope/GME Remote head UHF/Sheepskin Seat Covers.....Next on list Dual Battery Sys...In Dash GPS...Rear Diff Lock
    • #77
      Just ordered one too. Looking forward to adding a useful toy to the prado.
      • #78
        [QUOTE=Matt - mr4x4;281770]Hi all,
        Just received my new Scangauge v4.02 from Matthew at Ample Outdoors in Lithgow (www.ample-outdoors.com.au).
        The unit is very basic to fit up, especially in a 120 Prado. I just dropped the panel below the steering column, plugged the big connector straight into the OBDII port and cable tied the excess cable up so it wouldn't wander about. I then refitted the panel and used the Velcro sticky strips to fit the gauge on my steering column, allowing enough cable to adjust the steering column up and down.
        Hi Matt,
        Do you have to drop any panels, i looked for my OBDII port & i see one on the right hand side above the go pedal, is there anoth
        er connection behind the panel at the bottom of the steering column??
        Steve j
        • #79
          Just fitted mine up. Excellent service from ample outdoors, very quick delivery.
          As has been mentioned very easy to fit and program the basic settings. I haven't bothered with auto trans temp yet, but will have a go this weekend.
          Just need to remember to watch the road too!
          • #80
            Hi All,
            Well I've installed my scangauge, did'nt
            Need to remove any panels, just fed cable
            Up thru steering column, then programmed
            Basic settings, then in Xgauge set auto trans
            Temp settings using parameters from
            Earlier post, just need to do fuel fill now!
            So far so good.
            Steve J
            • #81
              Originally posted by Hoskie View Post
              Just sorted the Transmission Fluid Temperature (TFT) seems to work on my 150TD with v4.02 and have aslo confirmed it on a 2007 D4D 120
              Thanks to James from Linear Logic........
              Just set up xgauge as per the instructions with the following settings.
              TXD: 07E121D9
              RXF: 032100000000
              RXD: 2808
              MTH: 00010001FFD8
              NAM: TFT
              This series of codes worked for me, too Nov 2008 D4D
              • #82
                which are the correct settings on either the scanguage web site or in these threads for an auto transmission setting for a kakadu 2012
                A Happy Camper
                Carey
                Nov2012 Kakadu D4D auto,Toyota bar, IPF900xsHID, ARB/Redarc SBi12 Dual battery, diode,UHF3540, Provent style oil catcher.
                • #83
                  Has anyone been able to track down the engine oil temp or pressure codes?
                  • #84
                    Ordered today now will have something to do if the rain does not stop coming down
                    Hope it is water proof the papers are all doom and gloom ie cyclones, elections, drugs in sport to mention a few
                    May need to turn the Prado into an arc now that would be a rig build up
                    2009 120TD Auto, Snorkel, Tow, Soveriegn Bull Bar, Dual Batteries, Rear Suspension Air Bags, UHF, Toyo Open Country Tyre AT II,, ScanGauge
                    • #85
                      Does the Scan Gauge read the diesel injector compensation codes?
                      Thanks Glenn
                      • #86
                        Temporarily installed scanguage in the open ashtray
                        May even leave it that position
                        • #87
                          Very cool thanks for sharing Heath, will give it a crack on mine
                          Craig
                          • #88
                            ok i have read the last 6 pages and can't find a bit of info on throttle position. I have 2 scangauges hooked up with a cable between them for extra gauges and would like to know what percentage the throttle is on cruise control.
                            Looked on http://scangauge.com.au/?page_id=338 and info for TFT.
                            Anyone got any ideas.
                            • #89
                              Had to send my new scangauge back. Was doing strange things like not being able to select 'c' in temperature set up. Also some of the x gauges could not be set or edited. Tried doing a factory reset but no good. Hopefully will get a new unity back this week. When this one comes back will send the old one in for the update. Running two gauges with daisy change gives a lot of gauges to watch. Put new unit in the front of the console with the TPMS gauges.
                              Rusty62
                              • #90
                                Already received the replacement unit. Programmed the x gauges and presto both temperature sensors are visible from the auto.
                                Thanks Ample Outdoors.
                                Rusty.
