I want to run 2 gauge 6 B&S (13.5 mm sq) cables from my alternator to my third battery in my camper. Wholesalers will sell me 30 metres but I only need 8. The usual retailers dont stock heavy cable. Where can I get 8 metres of 6B&S cable in Sydney?
Where in Sydney to buy Heavy Duty 12v Cable?
I saw some of them from Supercheap Auto store in Bankstown and Canterbury about 2 months ago. They will sell each meter for your demand. You can call their stores to double check if they still have in stock.James
- Manual RV 97 3.4 Petrol
2" TD-BFG KM2 265/75/16-Dual battery-Maxtrax-Hi Lift Jack-DVD Kenwood 6.1"-12.1" sunvisor LCD x 2-9" headrest LCD x 2-9" HID 100W internal ballast x 6-HID headlight-Air pump in engine bay-Uniden 7760NB-Roof rack TJM-Roof box
Originally posted by dickybird View PostI want to run 2 gauge 6 B&S (13.5 mm sq) cables from my alternator to my third battery in my camper. Wholesalers will sell me 30 metres but I only need 8. The usual retailers dont stock heavy cable. Where can I get 8 metres of 6B&S cable in Sydney?My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
Larrikin Products in Seven Hills, hes the importer and sells by the meter.
I can buy from him about 5 meters for the price of 1 meter from Supercheap.
02 9838 4233
http://www.larpro.com.au/
Tell him 1coolbanana sent youMarc, 2003 Grande V6, Just a Bit of Stuff Done..........Work in progress.
Options for 6B&S Cable
Originally posted by samo View Posttry a local auto electrician they usually have the gear you need and they are usually around the corner. cheers samo
AKS in Sydney will sell you a 50 Meter roll for $280.
Found a guy on eBay from Bairnsdale will ship 6 Metres to you for $69. There are also other on eBay.
Tycab AWC2168032 looks pretty good.
GaryEbay
