My 2004 VX Prado came back from a service with the news the High Mount Stop light was not working and needed replacement at $300+. I hope to replace the LED strip or put in a replacement from a wrecker. There are no screws on the outside and it looks inaccessible from the inside even after removing the top rear door trim. Any advice appreciated!
How do you remove & replace the High Mount Stop light?
Maybe it snaps in from the outside
http://www.toyodiy.com/parts/p_G_200...PGKQ_8117.html
You're not the only one it seems where Toyota wants $300 for it.
http://www.pradopoint.com/showthread...t-in-rear-door
Makes me think that the whole thing is a sealed unit. Best that you check it is not a wiring problem. What did the dealer do during the service?
There are three tabs on the top that can be depressed with a length of thin celluloid or a plastic spatula from the outside while manipulating bottom tabs from the inside with a small screw driver ( pop the inside upper trim off first!) The whole light pops out with not a lot of force, just wriggle, but the foam seal gets shredded. The LEDs had failed. I cut a hole each end in the red lens and inserted a $13 LED strip from Jaycar with re soldered wires to the plug and fabricated a new foam neoprene seal from Bunnings, tested the brake light before pushing the assembly back and then completed the repair for about $22 instead of the $330 + labor Toyota wanted.
