Hi ALL
Not sure if this is an electrical issue however I suspect it is. The aircon compresor is intermittently turning itself off, via the clutch on the compressor. The light on the interior button is lit however I can tell that its turned itself off...
I've had the bonnet up under the carport and noted on the odd occasion I press the button I dont hear the compressor clutch engage. I'm suspecting a relay but as usual, the fusebox on the LHS wheel arch is pretty cryptic. Yes there are relays in there but which one is it ? :-)
Is it a relay I can get at an auto electrician or do I need to take out a home loan and go to Toyota ? I've re-seated teh relays but no change...
Any info would be appreciated..Pete
