Hi, just had to take our 1998 Prado down to jump start our 120 series vx, Wife left the lights on. The earlier model has an audible beep when lights left on and keys removed to remind you to switch off. I looked at the 120 series manual which advises that if lights left on they switch off when drivers door opens and keys are in the off position, ours does not, hence the flat battery. Are there other settings that I'm missing to get the correct function working, or should i take it to our local dealer?
Headlights not switching off automatically
Sorry for hi jacking, but closest thread I could find to suit my problem, without starting a new one...
Just wired up some Genisis HIDs in my 120, and I have a small problem..
Turn headlights ON = lights come on
Turn HIDs to ON.. = nothing
Push light/indicator stalk forward to high beam= lights on high beam , and HIDs ON..
Pull light/indicator stalk back , = everything drops to low beam
Turn lights off at indicator stalk ( twist off) = lights turn off... But HIDs turn ON
I followed the instructions ( well I think I did ) ... Only one brown wire that splices into headlight wiring.. Headlight has 3 wires coming out...
What have I done wrong???
Originally posted by Crusa View PostSorry for hi jacking, but closest thread I could find to suit my problem, without starting a new one...
What have I done wrong???2005 Black gxl 1kz, Steinbauer chip, ome lift, arb delux bar, Lightforce genisis 210's, 30inch led light, tigerz roof rack, GME 3540 uhf, genuine towbar, custom spare wheel spacer, ors draws, drop slide, waeco, dual batteries, twin locked, st maxx tyres, winch.
Soon to come-35's and longer shocks.
Originally posted by ChrisS View PostHi, just had to take our 1998 Prado down to jump start our 120 series vx, Wife left the lights on. The earlier model has an audible beep when lights left on and keys removed to remind you to switch off. I looked at the 120 series manual which advises that if lights left on they switch off when drivers door opens and keys are in the off position, ours does not, hence the flat battery. Are there other settings that I'm missing to get the correct function working, or should i take it to our local dealer?2005 Black gxl 1kz, Steinbauer chip, ome lift, arb delux bar, Lightforce genisis 210's, 30inch led light, tigerz roof rack, GME 3540 uhf, genuine towbar, custom spare wheel spacer, ors draws, drop slide, waeco, dual batteries, twin locked, st maxx tyres, winch.
