It might be easiest to run it inside the chassis rail, then if you go to the passenger side rear quarter panel, you will find a grommet at the bottom. You should get it in through there. Have you already bought the 6 B&S?
While you a at it I'd cut the usless cig plug of the Waco and put either an anderson plug or mini anderson power pole style on it.
